EG hatch engine swap
Old Sep 6, 2004 | 07:21 AM
honda2k's Avatar
Default EG hatch engine swap
hey i saw this 93 hatch in a autobuy. Its a 93 dx AUTO. know i always wanted to do a engine swap and this is my first time. the two questions i got is. what engine would be best for just a swap. i am not going to change the internals or add turbo or anything, just engine swap. im thinking a b18c1 with its tranny, i was also thinkin about a b16a2 with a gsr tranny. Now about the shift linkage, Is it going to be that hard to make it manual???? need help
Old Sep 6, 2004 | 07:28 AM
DemostheneZ's Avatar
Default Re: EG hatch engine swap (honda2k)
OMG, why don't you try searching before making THE most idiotic post on h-t. this question has already been asked like 3 times today, first of all, PUT IN ANYTHING YOU WANT
***Forum Rules and Guidelines - READ THIS BEFORE POSTING! 5/23/04***
[FAQ] What swaps are available for my Civic?
Old Sep 6, 2004 | 07:33 AM
92RED Hatch's Avatar
Why would you want to get a B16 and use a gsr tranny? Most people would rather have the b16 tranny with their gsr swaps because of how close the gearing is. Also In the B18C5 motor or Type R motor whichever you understand uses the same gear ratios as a B16 tranny....Try and do some searches about what you're about to embark on you'll learn about not only what you'll need to make your auto civic into a manual but also you'll yearn a little something about these motors and trannys and which setups are the most ideal....good luck
Old Sep 6, 2004 | 07:47 AM
honda2k's Avatar
Default Re: EG hatch engine swap (92RED Hatch)
so its gunna be complicated from makin it from auto to manual huh?
Old Sep 6, 2004 | 06:56 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda2k &raquo;</TD></TR><TR><TD CLASS="quote">so its gunna be complicated from makin it from auto to manual huh?</TD></TR></TABLE>
Its not the easiest thing in the world, but it can be done without too much hassle. You will need to locate a 5 speed pedal assembly first. I have one for sale if you are interested. You will also need a clutch master cylinder, slave cyclinder, and all the hydraulic lines.
marksae
Jun 19, 2007 06:35 PM
jikespingleton
Feb 27, 2007 06:39 PM
devang230
Oct 10, 2005 11:18 AM
allmotorEG-SI
May 12, 2004 08:08 PM
