What does this connect to?
Old Sep 13, 2004 | 12:46 AM
Neondog82's Avatar
Default What does this connect to?
I want to know if anyone here knows where this goes to. It sits right under the distributor, and behind the coolant intake temp sensor (I think that is what it is called) It is a 94 H22A2. Also I was curious if you could tell me the wire colors and the pin outs so i can run them to my ECU. My stock Civic harness has nothing to go there. Any help will be much appreciated.
http://www.geocities.com/neond...1.jpg
http://www.geocities.com/neond...2.jpg
Old Sep 13, 2004 | 07:16 AM
boosted_dc2's Avatar
Default Re: What does this connect to? (Neondog82)
looks like the water temp sender for the ecu, i dont know h22's at all so its just a guess, it must be water temp related though because of its location.
Landon
Old Sep 13, 2004 | 12:40 PM
Neondog82's Avatar
Default Re: What does this connect to? (boosted_dc2)
The only thing is that sensor over to right of it is a temp sensor, and there is another temp sensor for the exit to the heater core, I dont think (but there could be) three temp sensors in there. My civic harness has nothing that matches up with it though.
Old Sep 13, 2004 | 01:30 PM
that one with only 1 wire is the temp sender for your guages only. then there is a temp sender for the ecu and a temp sender for the thermo-switch im pretty sure.
Landon
Old Sep 13, 2004 | 01:58 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">that one with only 1 wire is the temp sender for your guages only. then there is a temp sender for the ecu and a temp sender for the thermo-switch im pretty sure.
Landon</TD></TR></TABLE>
Yep, the 1 wire is just for your guage. The white sensor is the coolant temp sensor for the ecu and the sensor on the coolant neck is the fan switch.
Old Sep 14, 2004 | 12:48 PM
Neondog82's Avatar
Default Re: What does this connect to? (Slopoke)
Anyone know the pinout and the wire colors so I can add/check my Civic harness to run this? Just to make it clear I am looking for the white connector with nothing on it.
busyychild
May 6, 2008 11:09 AM
Carbcivic
Mar 26, 2006 01:52 PM
Finest
Nov 19, 2003 08:15 AM
JoshM
Jun 2, 2002 06:11 PM
