TEIN RA's on DA Integra...what else do I need besides ITR rear LCA's?
I am about to purchase a set of Tein RA's for my 92 Integra, but before I do, I need to know if I need the DC/EG front lower control arms. The guy is including the ITR lower control arm's, but to my knowledge, I can't use them. Help me out soon please!
Re: TEIN RA's on DA Integra...what else do I need besides ITR rear LCA's? (HONDA_TYPE_R)
you'll need a set of JDM ITR rear LCA's and any 92-00 civic or 94-01 integra front drop forks (not LCA's). 94-01 integra front LCA's are NOT compatible with the DA chassis.
Re: TEIN RA's on DA Integra...what else do I need besides ITR rear LCA's? (Katman)
Sweet. I knew I was wrong somewhere. I already have the ITR LCA's, now I have to find a junk yard and get the drop forks. Anyone selling some?
Also keep in mind the DA's rear spring height is about 1 1/2 inches taller than the average spring. Keep that in mind when installing your rear suspension and adjusting it. Last night i just did rear itr lca's and omni power coilovers setup for an itr. When i first bolted the rears on it was insanely dumped to the floor.
Re: TEIN RA's on DA Integra...what else do I need besides ITR rear LCA's? (MikeySpec)
This was on a DA too huh?! So I could just leave it at max height and still get a 1 1/2" drop...not bad I guess. Did you use the DC drop forks? I still need to find some
Well im not 100% sure if the tein height is the same as stock. But know if you were to swap some rear springs off a crx it'd definitely drop the back of the car over an inch. The rear lca's bolt right up along with the rear shocks. I had to use eg/dc front forks with this setup. But im lovin it alot. The DA chasis has much better rotation than my crx.
I hope the height is close to stock. I got a great deal so I'm stoked. They were the HA's for the ITR. CRX's are near impossible to rotate. I had a hard enough time in my EF hatch when I had her. I've been able to make my DA spin donuts like it's rwd in the snow...have no clue how either, but she did it.
