Fuse boxes and Sensors and Wiring stuff!
Hi,
I'm in the process of doing a JDM H22A motor swap in a DC4 Integra. Now, it seems we Canadians are blessed with engine bay Fuse boxes that don't have ELD sensors. It says so right there in the service manual, next to the * USA ONLY. This also comes with the fact that our Alternators have only 3 wires (wht/red, wht/blu, blk/yel).
Now, running the wht/grn wire to the ECU is not a problem. Only thing is, I need to put in a ELD and wire that to the ECU. The fuse box being the fun closed black box it is, I was thinking of simply swapping in a USA fuse box from a US importer scrap yard we have here. Only problem is he doesn't have any 3rd gen integras in stock.
So now i'm left wondering if there's any other Honda fusebox that will just drop right in with a ELD or if there's a way of installing a ELD in a ELDless fuse box ?
Re: Fuse boxes and Sensors and Wiring stuff! (RedK)
The fuse boxes on 92-95 Civics, and I think 96-00 Civics, are almost the same. The only difference I see between my gf's 94 Civic box and mine (94 Integra) is that the relays are assigned differently, and an unused relay slot in mine is used in hers.
