is it worth getting a h22obd2 than a h22a obd1
my friend has a 98 h22 auto for sale hes gonna give me the motor for $500 and i can pay him $500 whenever else. its never been in his car. but i have a 95 lx accord coupe. what parts would i need to make the motor a obd1?? so i can fit it in my car??
Re: is it worth getting a h22obd2 than a h22a obd1 (mixxxwell)
All you need to do is, take your stock harness and put it on the obd2 h22(this will require you to use some of the obd2 plugs), add the necessary wiring for vtec, knock sensor, and IAB.
and then get an obd1 p13(h22 ecu) and your good to go.
Re: (mixxxwell)
Yes, you can do it that way, but it will be more expensive.
The only reason they are telling you to get the obd1 stuff is becasue the clips are different.
You obd1 engine harness clips wont plug into the obd2 injector and distributor clips (everything else will plug in, though).
Its cheaper to buy an obd2 engine harness and put the obd2 clips for the injectors and distributor on your obd1 harness.
Contender25
08-16-2007 07:14 PM
