New H22 ek problem
Old Sep 4, 2004 | 10:02 PM
Jago's Avatar
Default New H22 ek problem
got everthing running now i've got a new problem It runs and i'm almost done.
but now at idle the tac stays at 8k. I switched a distributer wire
im sure. which ones do you think they are here is a pic of my wiring.
Old Sep 4, 2004 | 11:14 PM
Jago's Avatar
Default Re: New H22 ek problem (Jago)
I used the civic harness wih prelude plugs
Civic Prelude
TDC + grn to orn/blu
- red to wht/blu
CKP + Blu to blu/grn
- wht to blu/yel
CYP + yel to orn
- blk to wht
I had three wires left two of them were for the coil
and the colors match. then one left over on both the plug and harness
so I connected them.
Old Sep 5, 2004 | 11:10 AM
Newman's Avatar
New User
Try this. Make sure that your cluster is getting a clean signal first off. Pull the cluster out and find the blue wire on the left side cluster plug (closet to the driverside window). That is your tach wire.... splice into it (or cut it off temporarily so you get a clean true signal) and run a wire from that back to the negative side of the ignition coil. See if the tach works.... if so, then you know somewhere the wiring in the harness is probably grounding out. If you still have the same problem, then check your distributor wiring.
Old Sep 5, 2004 | 06:07 PM
Jago's Avatar
Default Re: New H22 ek problem (Newman)
started working on it today it worked fine when I got started. whent to drive it around the block tack dosn't work at all. I've got a code 4 open CKP sensor
Old Sep 8, 2004 | 07:58 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Gumby?
Old Sep 10, 2004 | 09:33 AM
Adam.'s Avatar
Maybe the distributor is going bad. Mine started acting wacky the day before it died.
Old Sep 12, 2004 | 09:22 PM
Jago's Avatar
Default Re: New H22 ek problem (DarkKnight[DMD])
yea got a distributor coming. think wont rev over 3k
kseriesdreams
Dec 26, 2010 04:56 PM
vtechjunkie
28
Mar 16, 2010 11:14 AM
crxcel
Jul 8, 2006 11:15 AM
VegasHB
May 18, 2006 12:22 PM
joecivic93
Jan 6, 2004 10:07 PM
