Need wiring help ASAP
Hey guys, I'm new to the forum so I only get FIVE responses per day so I'll try to be as specific as possible.
First off, I have a 94 Honda Civic VX Bubbleback (SOHC VTEC Stock) that I'm swapping in a JDM B16A2 (DOHC VTEC).
The first question is regarding wiring. I used the Stock(USDM) ECU-Firewall harness and the Donor (JDM) Firewall to Engine Harness. I extended the power wire and two connectors to reach across the engine bay since it's reversed and everything plugs in fine EXCEPT one plug (USDM) on the passenger side shock tower. (JDM ECU plugged into the stock USDM wiring inside the car)
That said, I tried to start the car and it just cranks w/o spark. Is there something I'm missing? Do I need to wire up a knock sensor and if so, HOW??? I don't see any extra wires from the JDM harness...
Also, I need a replacement oil pressure switch. The one on TOP of the oil filter, not under it. What's the part # (available in the US) for that? If that's missing, would that cause the car to not start/no spark?
If anyone is available through AIM to help me, please IM me... My SN is DTKim. Thanks.
This car is needed for college and college is already in session...
I know I'm so close....
NEW UPDATE: Plugged in stock wiring for everything (USDM all the way). Couple things I need to extend... but now the question is what else do I need to do? (New wires, etc.) and how? Thanks...
Modified by DTKim at 11:09 AM 9/7/2004
I know I'm so close....NEW UPDATE: Plugged in stock wiring for everything (USDM all the way). Couple things I need to extend... but now the question is what else do I need to do? (New wires, etc.) and how? Thanks...
the knock sensor would not affect the car starting. I would check that the dizzy wires all got hooked up right, were you swapping to obd1 from obdo at the same time? if so try swapping the 2 whit wires on the dizzy.
The car is OBDI and the engine is OBDII.
Also, what radiator should I order cause the stock one has smaller holes/connections than the new motor. And any part #'s for the hoses? Thanks.
Anyone have a link to how the wiring changes should be like? I've been searching but can't find anything!
Okay, scratch everything... apparently all my problems have been caused by a few faulty parts... GRRRRRRR... For future reference:
1. No Spark - Ignition Coil
2. Not staying on - Ignition Key Cylinder not locking in (ON) position after cranking.
3. Low/bad idle/slow revs - Bad Fuel Injector.
So thanks for all your help guys.
Dukie432
30
Mar 31, 2009 04:37 PM
