K20 in ef8/ee8 , block height issues
Old Aug 31, 2004 | 10:45 PM
REX VT's Avatar
Default K20 in ef8/ee8 , block height issues
I have the 1st option on a '02 CTR with side damage. This might be an interesting project to build the first K20 CRX in Europe but what's holding me back are the dimensions of the block.
Anyone?
Old Sep 1, 2004 | 04:39 AM
Charlie Moua's Avatar
Default Re: K20 in ef8/ee8 , block height issues (REX VT)
dunno that would be a very tricky swap.
have you tried to measure the height of the motor itself then compare it with the height of a b18 motor
Old Sep 1, 2004 | 06:51 AM
6SPD_EK's Avatar
cut a hole in the hood - been done before https://honda-tech.com/zerothread?id=869343 - BTW he rips the 1/4 mile in 11.8 seconds cantact Pacman if you have more questions - I believe he is the only one with a k powered CRX
Old Sep 1, 2004 | 07:26 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: K20 in ef8/ee8 , block height issues (adirondackR)
Yeah, if you want any kind of reasonable ground clearance, you will need a hole in the hood or a custom hood.
Old Sep 1, 2004 | 08:57 AM
JDMotive's Avatar
Default Re: K20 in ef8/ee8 , block height issues (rochesterricer)
Ive put a motor in our drag crx,but never actually got it running and sold the car engineless to get a eg hatch.I had a one piece front end so hood clearance wasnt a problem,but you will need to cut the hood or get an aftermarket cowl hood to have the axle angle as straight as possible.You will have clearance issue with the rear crossmember.The transmission hits it so you will need to massage it with a hammer and possibly cut it.You have to do this along the whole rear crossmember,as you wont have any room for the header to pass either.
Old Sep 1, 2004 | 11:31 AM
REX VT's Avatar
Thanks for the info so far
k20rex
Feb 28, 2010 06:05 PM
shutuprichard551
13
Aug 22, 2009 09:53 PM
db8gsr_teg
Feb 28, 2006 08:51 AM
Shellshock2004
Feb 26, 2003 04:06 AM
enhancedCL9
25
Feb 6, 2003 06:14 AM
