need help with h22 swap
Im putting a h22 in my 98 civic hb, I have the back motor mount on, trying to get the tranny mount on, i need to align the holes up but the valve cover hits the frame,which is the best way to muont the engine in??
http://img300.echo.cx/img300/6588/dsc007261pk.jpg
http://img118.echo.cx/img118/7408/dsc007359rp.jpg
http://img118.echo.cx/img118/7329/dsc007344yp.jpg
Modified by ekblacknight at 2:30 PM 6/5/2005
Re: need help with h22 swap (ekblacknight)
Only thing I could say is that the trans mount bracket is on upside down it just looks like that side of the motor is sitting to high and thats why the valve cover is hitting.
Re: need help with h22 swap (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">something is wrong with ur mounts. what kind/ brand are they?</TD></TR></TABLE>
Or the car has been in an accident.
Also, check the driver mount to see if it is broke (does not look in the pic, but check)
Re: need help with h22 swap (Turbogixxer)
pass mount not bolted down, my car hasnt been in a accident that I know of
should I mount the trans and pass mounts first then try to put in the back mount?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblacknight »</TD></TR><TR><TD CLASS="quote">
should I mount the trans and pass mounts first then try to put in the back mount?</TD></TR></TABLE>
Thats what I do, line up all the mounts, and put the bolts in, then tighten them down. See where it sits then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblacknight »</TD></TR><TR><TD CLASS="quote">pass mount not bolted down, my car hasnt been in a accident that I know of
YEA, you should bolt in pass mount first ( but not all the tight), then bolt in the trans mount then once everything is aligned properly you then tighten the back mount.... after everthing is bolted in make sure your value cover is straight so when you launch you will launch straight......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblacknight »</TD></TR><TR><TD CLASS="quote">I got HCP, there on rite</TD></TR></TABLE>
Thats weird, that drivers side mount just doesnt look like the ek/h kits ive seen. Looks almost like something is missing. You sure you got genuine HCP mounts? They are often duplicated.
Like here, heres a drivers side mount from JDMshit.com
Looking at your pic, it kinda looks like yours is missing that urethane (?) cone looking thing.
I dunno, i could be way off here. Hopefully you get her figured out.
Re: need help with h22 swap (AudioFuct)
are the mounts all tightened down?
I made the mistake of tightening all the mounts down before I installed the motor. So when I went to drop it in, nothing would line up. I loosened up all the bolts so the mounts were able to move a bit and it popped right in. Then I straightened out the motor and torqued everything down. no problems since
good luck
good luck
bubblehead
08-14-2006 09:55 PM
