H22 crx front crossmember??
Got an 89 crx with a h22 in it. I modified the stock crx crossmember to fit but I have no room for a header. Are there any aftermarket crossmembers that will fit onto a h22 crx and have room for a header?
Re: H22 crx front crossmember?? (Slavko)
full race?
Re: H22 crx front crossmember?? (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">full race?</TD></TR></TABLE>
I don't think the full race will fit I think the radius rods will hit the crank pulley.
you need custom ones.
Re: H22 crx front crossmember?? (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">
you need custom ones.</TD></TR></TABLE>
If the stock one fits without the crank pulley hitting the radius rod, so will the Full Race.
Brian
Brian
I did not modify the radius rods. But i think the previous owner did. I will take a pic so you guys can see. I only had to cut out pieces from the crossmember where it needed, and bolted it up.
So anyone know if any aftermarket crossmember/traction bar will fit h22 crx yet?
Heres the pics of my stock crossmember/radius rods. Look at all that room!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">did you buy this car from one fab</TD></TR></TABLE>
yeah. why?
yeah. why?
just thought it looked familiar,Thats not the cross member they had on there is it? that looks kind of tight. I sent you A IM
Modified by dragline at 9:46 PM 5/29/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">just thought it looked familiar,Thats not the cross member they had on there is it? that looks kind of tight. I sent you A IM
Modified by dragline at 9:46 PM 5/29/2005</TD></TR></TABLE>
No they had the place racing crossmember on the car. It came with the car but it was bent. Probably from when the owner hit the curb.
The full race one should fit with a single belt crank pulley and install the arms to the forks and you'll have clearance.
Re: H22 crx front crossmember?? (93b16hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16hatch »</TD></TR><TR><TD CLASS="quote">The full race one should fit with a single belt crank pulley and install the arms to the forks and you'll have clearance. </TD></TR></TABLE>
I already got the place racing one to fit. thanks anyways.
Re: H22 crx front crossmember?? (djnikko)
I have spoken with full-race.com and they can assure me with the HASPORT Mount kit the full-race crossmember will fit without any modification to the radius arms.
djnikko
09-29-2005 07:20 AM
