Honda heads: why won't this work??
I keep reading over and over that the h23 head is exactly the same as the dohc f22b head. I also read over and over that you can't swap heads between f and h series. I the h23 head is the same as the one on the f22b and the h22 head can go on a h23 block, then why can't the h22 head go on an f22B?
Re: Honda heads: why won't this work?? (90AccordSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AccordSi »</TD></TR><TR><TD CLASS="quote">I keep reading over and over that the h23 head is exactly the same as the dohc f22b head. I also read over and over that you can't swap heads between f and h series. I the h23 head is the same as the one on the f22b and the h22 head can go on a h23 block, then why can't the h22 head go on an f22B?</TD></TR></TABLE>
Ask this in the prelude forum, but i believe they've already done it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AccordSi »</TD></TR><TR><TD CLASS="quote">I keep reading over and over that the h23 head is exactly the same as the dohc f22b head. I also read over and over that you can't swap heads between f and h series. I the h23 head is the same as the one on the f22b and the h22 head can go on a h23 block, then why can't the h22 head go on an f22B?</TD></TR></TABLE> What forum are you reading? HT is full of how possible it is to make a f & h motor. Hell I have one in my EG.
Here is a good link for you.
https://honda-tech.com/zerothread?id=776837
there are more.
there are more.
Ok so its not as simple as swapping the heads between motors of the same series but its not any more difficult. Thanks. That was a very informative link!
Now I feel stupid for gettng rid of my old f22 block when I did my swap. I've still got alot to learn!
