check engine lights?
Old Jun 9, 2005 | 01:52 PM
Touge Tuning's Avatar
Default check engine lights?
k guys, im throwing 3 codes, code 10 IAT, code 3 and code 5 (MAP). what would be the problem with the map sensor, its plugged in and working properly.
Old Jun 9, 2005 | 02:27 PM
also when i check the codes my abs light flashes aswell?
Old Jun 9, 2005 | 03:20 PM
ok i reset the ecu and im getting no codes, the ABS light will still flash when i connect the jumper for the cel light and it will stay solid when i start the car.
Also the car will start up and will be a little rough, then it will idle smoothly and then it will just suddenly die. Does anyone have any ideas what i should be looking for to fix this problem?
ShatiaNichols
Jan 23, 2012 07:13 PM
Tegraracer90
Jul 7, 2009 06:03 AM
shortlid
Mar 15, 2006 05:04 PM
anonchild
Feb 20, 2006 05:13 AM
2000GSRT
Aug 5, 2004 04:06 AM
