Tranny leak. Axle issues?
K guys, I got h22 swapped in 96 coupe. Using accord midshaft, with 93 teg axles. Everything grabs and there is no binding. Now, when I look at my inner joint on the passenger side, there is tranny fluid all of it and you can tell it is flinging off the axle as it is driving. Also, when it sits for a long time. there is a puddle underneath the car about 1ftX1ft. Why is it doing this? The seals were replaced and the axle doesn't look like it will pop out at all. I have looked all over this thing. There was a crack in the casing that is now fixed. But the leak is still there.
Re: Tranny leak. Axle issues? (Sixgundone)
well i had the same problem but changing the outer seal on the tranny side fixxed my problem? im clue less..
well my tranny was leaking before and i had changed all my seals so i jacked it up and discovered that the fluid was coming from the bottom bolt off the tranny and i just simply tighted it and solved my problems..... i think the heat expanded the bolts and caused fluid to seep.... so try tightening the bolts and just follow the leaks.....
I had this same problem but my swap was b18b in a eg.Tranny fluid was all over the pass side and left a puddle over night,it turned out when the axles got put back in the pass was a civic not a teg like i needed.Changed the axle and fixed the problem.
we also checked the seals and replaced them at first to see it still leak then figured it out.
Jonovision
01-04-2006 04:04 PM
h22zexhatch
06-22-2005 10:29 PM
EJ1 wilcox
06-21-2004 10:46 AM
