EK engine harness removal
How do you remove the engine harness on an EK, do you pull it into the cabin or do you pull it into the engine bay? I tried pulling the wires through the grommet on the passenger side but it seems like the wires go to the drivers and passenger side so it wont budge.
take off the battery trey. there are 2 bolts that hold the harness in. and pull throught the engine bay. there is also a zip tie holding it on the cabin side to the ecu bracket.
daver
Apr 27, 2006 05:04 PM
