crx ef8 with 93gsr front brakes ??
Hi, to all I have a 90 crx ef8 , with 93 gsr front brakes, I swaped the entire knuckle as one unit. I used my stock UCA & LCA. i DON'T UNDERSTAND everything bolted up fine, although it seems as i have positive camber and my rims with 195 60-14 with 45 off set stick out of the fender, about 1 inch how can i remedy this problem or better yet what is the problem??
your help is appreciated
thank you
thank you
Re: crx ef8 with 93gsr front brakes ?? (revin=smiles)
the 93 GSR knuckles are too tall. which means they are going to stick out. what you need to do (if you want to do this the right way) is get some 90-91 civic EXknuckles and calipers...etc..the whole deal. you can still use your own UCA and LCA cuz, guess what THEY ARE EF PARTS! they will fit perfectley this way. hope it helps...peas
https://honda-tech.com/zerothread?id=1279827 or look at that thread and make your own judgements...you could have searched for this info too
ooairewreckoo
12-13-2005 12:14 PM
enthusiast128
11-14-2001 01:42 AM
