k20a swap plz help
k20a swap plz help
i have a question about the k20a swap. you know how when you get the k20a with the ecu the ecu only respnds to the transponder key, what if u dont have that key. what do u do then? thanks
Re: k20a swap plz help (CMCivicSI)
From what I heard on the K20a ECU you can bypass the immobolizer. I'm pretty sure there's a couple of guys on K20a.org running K20a ECU.
Re: k20a swap plz help (Spoon Si)
no, i know they reprgram the ecu to work with youur key... my main question is what key do you use... can you use the key that you regulary use or do you have to use a newer honda key with that chip in it?
Re: k20a swap plz help (HKSTurboDrifter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HKSTurboDrifter »</TD></TR><TR><TD CLASS="quote">no, i know they reprgram the ecu to work with youur key... my main question is what key do you use... can you use the key that you regulary use or do you have to use a newer honda key with that chip in it?</TD></TR></TABLE>
No reprogramming anything. You keep the key that came with your car.
This is correct:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon Si »</TD></TR><TR><TD CLASS="quote">From what I heard on the K20a ECU you can bypass the immobilizer. </TD></TR></TABLE>
This is correct:
Re: k20a swap plz help (k-series)
If you are using a k20a (JDM engine and ecu), then you don't need to do anything. There are no immobilizers in the Japanese cars. You'd run one of the PNP harnesses provided by multiple companies, use your stock ignition, and go...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karcepts »</TD></TR><TR><TD CLASS="quote">If you are using a k20a (JDM engine and ecu), then you don't need to do anything. There are no immobilizers in the Japanese cars. You'd run one of the PNP harnesses provided by multiple companies, use your stock ignition, and go...</TD></TR></TABLE>
The above is somewhat correct, JDM K-series ECU's do have an immobilizer, but if you are using a Plug and Play harness they are very easy to bypass. The JDM immobilizer only controlls fuel (the fuel pump), where the USDM controls both fuel (the pump and injectors) and ignition.
Re: k20a swap plz help (Goatsterrman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goatsterrman »</TD></TR><TR><TD CLASS="quote">
The above is somewhat correct, JDM K-series ECU's do have an immobilizer, but if you are using a Plug and Play harness they are very easy to bypass. The JDM immobilizer only controlls fuel (the fuel pump), where the USDM controls both fuel (the pump and injectors) and ignition.</TD></TR></TABLE>
Oops... thanks for the knowledge!
hard_boiled_EG
10-15-2009 05:16 PM
Big Si Guy
12-30-2003 03:55 PM
