good motor mounts for b18 into an EG?
hey, i dont want to spend alot of money and i heard that the stock integra motor mounts will work for this swap. but i thought it would be a good idea to get some stuff motor mounts because im scared of other things breaking because im going FI in about a month. what are some good ones to buy? the avid ones on ebay anygood? but i heard those will lower the height of the motor? what should i get? thanks.
also, when i get the mounts will they come with the bolts needed? or will i just use my stock bolts?
Re: good motor mounts for b18 into an EG? (T4eg)
hasports are too much money. what other brands can someone recommend. think the stock ones will be ok?
Re: good motor mounts for b18 into an EG? (d16why8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16why8 »</TD></TR><TR><TD CLASS="quote">stock mounts w/inserts.then for the front lower mounts used jimfab. </TD></TR></TABLE>
is this what you are acutaly using...yes jimfab...i forgot the name...ill check those out
