few plugs left b4 swap done..help. have pics.
i have these 6 plugs that i can't figure goes where. they might be extra, but i'm not sure. i have a 96 civic hb dx, and did a 99 si swap into it. did the whole dash,floor, and engine harness swap. the first 3 are located on the left side near the fuse box, and the other 3 are near the right where the radio console is. they come off the main dash harness. any help appreciated.
left side
right side
left side
right side
Re: few plugs left b4 swap done..help. have pics. (97civic123)
first pic left to right, the plug with a blue and black wire, go to the factory alarm valet switch, whether or not you have that. the second plug light green, with a red stripe and white with a red stripe, i believe go somwhere under the dash near where your vin plate on the dash is, but underneath. i believe it turns the dome light on when, you open the door. and the pink and black, i believe go to the neutral safety switch, look for the plug on the top of the clutch pedal.
second pic i have no idea.
motoxx644
06-09-2008 12:27 PM
jdm_ef9
03-31-2002 05:05 PM
