OB2 JDM B18b into EG Help!
I have done numbrous swaps from b16 b18c's b18b's h22s f22. But this is the first time i have done a obd2 jdm swap into a eg. I dont know if its this is set up right but i keep shooting a MAP sensor code.
I have the motor setup like this: Motor is a 98 JDM obd2 B18b
Engine harness is from a usdm obd1 95 Integra
ECU i am running is a OBD1 P75
I checked the Map Sensor and am getting the right voltage (5 volts)from connector and changed it out with 3 others and is still shooting. The only change in the harness is that I extended the IAT to reach to the intake. And wired the connector for the distrubutor, and Alternator . I thought the harness is a direct plug in. Am i wrong? The reason i used the obd1 harness is so that i dont have to use a obd2 to obd1 boomslang.
Re: OB2 JDM B18b into EG Help! (CMCivicSI)
Figured it out. Warning, Make sure that the person that you install a motor for, knows how to install a V-AFC, it uses the signal from the map sensor. And if dont know theres a V-AFC installed and not pluged in this is a great problem. Peace
killaberna
27
08-26-2014 06:44 PM
appelsos
13
07-01-2011 04:25 PM
j.star
11-27-2008 07:49 PM
