b18b into 1990 civic, no fuel/ no fire, need help
Got power to the fuel pump and power to the distributor but I can't get the pump to prime on its own or the injectors to open up. And the distributor acts like its not getting a signal to spark. I'm not getting any spark at all.
I can prime the fuel pump manually and turn the motor over and I my fuel pressure gauge wont' come down below 42psi. Put a spark plug into each of the plug wires and none of them had any spark. I'm also not getting power to all of the wires at the distributor plug.
Anybody have any ideas?
Re: b18b into 1990 civic, no fuel/ no fire, need help (Redlineracer)
Main relay fried ? Those damn 88 91'a are so notorious fr having those things go out. Did it just start after the swap ??
Re: b18b into 1990 civic, no fuel/ no fire, need help (Moonshine Conspiracy)
I was able to fix everything sunday and monday. It was the main relay but it was my fault. How's the damn thing suppose to work if its not grounded? As far as fuel and fire though....After grounding out the main relay and actually getting fuel pressure and power to all the pins at the distributor, I still couldn't get any spark. So I took the distributor apart and found that the ICM(ignition control module not the ignition solenoid) was fried. After testing to see if each cylinder has spark(the freaking hole in my finger is proof of that) I still couldn't get fuel to my cylinders. I had perfect fuel flow from supply and return, but couldn't get my injectors to open up. So I found a wiring diagram for both the motor and the car and found a wire was missing from the wires I soldered together from the injectors. This happend to be the power wires that come from the main relay and get pulsed from the ecu. How's are teh injectors suppose to open w/o power right
So after all that, I turned the key and she started right up.
how did you ground main relay? also, does wire from crank sensor fire the injectors? which wire is it? where do I get a wiring diagram?
thanks
greghaney
thanks
greghaney
back from the dead
he's talking about grounding the engine
for the wiring diagram search on google.com
Waldron Racing
11-26-2013 06:45 AM
spnej1
77
02-02-2010 12:03 AM
JolToN49
11-20-2002 11:41 AM
