Air Conditioning Belt - 92 GSR w/ B16
Which belt should I use for a 92 GSR DA with a b16 swap? Will a GSR belt work? The Non-Vtec and the Vtec part numbers are different according to Acura.
-Rob
-Rob
Re: Air Conditioning Belt - 92 GSR w/ B16 (2manycars2choose)
As the b17 (stock 92 GSR) engine is basically a b16 with a longer stroke, using the same head and block, I'd guess that you'd use the stock belt.
Re: Air Conditioning Belt - 92 GSR w/ B16 (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 »</TD></TR><TR><TD CLASS="quote">As the b17 (stock 92 GSR) engine is basically a b16 with a longer stroke, using the same head and block, I'd guess that you'd use the stock belt.</TD></TR></TABLE>
OK thanks. Didnt take me that long to get an answer
-Rob
-Rob
ricin4ever
06-20-2008 09:31 PM
IntegraGSR(-1)
05-28-2006 05:22 PM
TheThiefTheKnife'NTheGun
01-25-2005 09:40 PM
