few auto to manual B series swap questions
k so im about to drop the car onto my B18b1 swap and im wondering a few things. First i need the actual bracket that bolts to the frame of the car for the upper tranny mount from a MT car correct?
2. The sensor on the front of the tranny is for the reverse lights?
3. if i dont have the ptank wire connected will i run into problems?
any help is appreciated:D
cool guy name
Re: few auto to manual B series swap questions (scarlemthug)
1 you will need the mt mount that originally comes on the car. So if you have a 95 civic you need to get a 95 civic mt frame mount.
2. yes
3 ????
2. yes
3 ????
yeah i have a 98 mount, and i just went and looked and the eg mount is welded on, looks like i gotta buy the MT EK mount. do i need the D series or B series mount or does it make a difference?
how do i wire up the reverse lights, do i needa run the wires from the tranny to the wires from the auto shifter assembly?
there is a wire on the OBD2a harness called ptank (fuel tank pressure sensor) and theres no wire on the OBD1 side
well i got the engine almost completely in today in a couple hours, just needa do a couple more bolts and waiting on the upper tranny mount and i should be good to go
still not sure what i needa do for the reverse lights but ill prolly figure it out.
benphillips
04-26-2007 07:23 PM
