97 JDM ITR obd2 to obd1 using p30 issues???
Background:
I have a 96 Civic Dx HB. Motor is a 97 jdm itr. Previous owner was running obd1, and had obd1 ecu. The shop that is doing my swap is converting to obd2 to match my car.
My plans were to find a 96-98 jdm itr p73 and run that. All the wiring has been done to mate with that ECU perfectly. Unfortunately, I can't get a hold of the guy that was going to swap me ECU's so now I'm stuck with everything back to 97 itr spec (electrical wise) and a jdm 92-95 p30 chipped by Erick's Racing (which was being used before).
My question is, if i were to buy a jumper from jhp or jdmsh!t for their obd2-->obd1, will i be able to just plug and play the ecu and start driving? or would i have to convert other things back to obd1 (dizzy, injectors)?
P.S. I tried searching, but nothing specific came up. I might not have been searching corrently, but please help me asap.
Re: 97 JDM ITR obd2 to obd1 using p30 issues??? (llxzxll)
i dont think you would have to change anything. I have a 97 civic dx that had a jdm b16. I was using a obd 2 itr ecu. When I used my buddies skunk2 ecu, I had to use a obd2 to obd1 harness and everything worked fine. I didnt have any problems and the car ran fine!!
Re: 97 JDM ITR obd2 to obd1 using p30 issues??? (EKhybrid)
sweet. so basically, you wired your jdm b16 to obd2 to match your car, and when you ran your friend's skunk2 ecu (which i presume is obd1) you simply used a jumper to run it, and the car ran fine?
if so, that's exactly the info i needed, and thanks a lot.
llxzxll
05-30-2005 06:21 PM
Nameless RB26
11-01-2002 06:17 PM
