LS/VTEC Header Question? VTEC or Non-VTEC?
Old May 31, 2005 | 01:52 PM
B16'D DA9's Avatar
Default LS/VTEC Header Question? VTEC or Non-VTEC?
Okay so I was wondering, I am buying a Header for my LS/VTEC this week and I was wondering if there is a difference between a LS Header and a GSR/Type R Header?
My LS/VTEC is not exactly as satisfying as I thought it would be, but maybe thats because I chose not to do pistons yet (using stock LS). Basically my motor is lacking up top a little bit, so I figured maybe its because of the Stock LS Header and Throttle Body I have on it right now. Do you think those LS parts still being on my LS/VTEC are really holding me back?
Thanks in advance to those who Reply...
Old May 31, 2005 | 02:22 PM
unknown0001's Avatar
Default Re: LS/VTEC Header Question? VTEC or Non-VTEC? (JayDeeEmDC4)
most likely because you are using the stock LS pistons is the main thing holding you back. I'm not too sure what the compression is but I'm guessing it's mid 9:1 and that's pretty low for a setup like ls/vtec
a header won't make much difference but if you do buy the header it would be best to get some higher compression pistons and you will feel the difference
Old Jun 1, 2005 | 01:30 PM
saleensolution's Avatar
Default Re: LS/VTEC Header Question? VTEC or Non-VTEC? (Mr.RHTuner)
pistons would be a big help however if your looking for a header than just get a four to one header like the jdm type r cuz it flows real well but any will do
Old Jun 1, 2005 | 06:05 PM
B16'D DA9's Avatar
what I need to know is an LS header the same as a gsr one? flow wise?
Because my friends Shop has a Header but its for a LS motor, is that the same part number as the one for a GSR?
Old Jun 2, 2005 | 07:47 AM
B16'D DA9's Avatar
BUMP
Old Jun 2, 2005 | 04:50 PM
al3e's Avatar
Default Re: (JayDeeEmDC4)
no sorry the GSR and LS headers ARE different... they wont line up right on the block.. from experience..
Old Jun 2, 2005 | 04:56 PM
B16'D DA9's Avatar
no sorry but i know that is wring because im using my stock ls header on my ls/vtec but what i want to know is the flow part of the 2
Old Jun 3, 2005 | 04:27 AM
Redcoupe's Avatar
What cams are you using? I have a friend who is using OBD-0 B16 cams and they are "like nubs on a cam". The car pulls hard but it lacks up top where you would think it would have alot of power.
Ls/Vtec-built bottem end. cam gears, intake, header, exhaust, no cat, vtec controller, and full MSD set-up.
Maybe you have the same problem. What year head do you have?
Old Jun 3, 2005 | 08:40 AM
dohcdelsol93's Avatar
Default Re: LS/VTEC Header Question? VTEC or Non-VTEC? (Redcoupe)
i have a ls/vtec with b16a head. I'm using a the stock ex. manifold from a 91 ls. It fits perfectly. I didn't even have to cut or re-bend any of the exhaust when I went from an ls to the ls vtec. I don't have much power up top either. I built my bottom end to lower the compression. Low compression pistons and big cam lobes don't perform well together unless boosted.
Old Jun 3, 2005 | 01:33 PM
B16'D DA9's Avatar
yea i know
i am using a 95 del sol vtec b16a3 head w/ my 99 block with 85k.
i think im gonna do cams this week (ctr intake, itr exhaust)
if not im gonna sell the motor as is for a gsr or just trade it straight up for a gsr.
any takers?
Old Jun 5, 2005 | 08:26 AM
ernald711's Avatar
ls/vtecs are monsters when you don't restrict the breathing... they love air. get better pistons, a better exhuast system (i.e. header, etc) and intake mani and tb. build your head if you have the money for it. i'm running .25 p72 pistons on my ls/vtec with a stock 16 head making 180whp.
Old Jun 6, 2005 | 06:00 AM
B16'D DA9's Avatar
i am building a second ls block now with p30 pistons and new rods? which kind<--?
also a block gaurd and rod bolts
hopefully it will be faster also a itr header
Old Jun 6, 2005 | 08:33 AM
miller.91.HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeEmDC4 &raquo;</TD></TR><TR><TD CLASS="quote">i am building a second ls block now with p30 pistons and new rods? which kind&lt;--?
hopefully it will be faster also a itr header</TD></TR></TABLE>
Use your stock LS rods with the P30 pistons but get new rod bolts. Also ditch the block gaurd it's a waste of money. My build
Old Jun 6, 2005 | 03:30 PM
B16'D DA9's Avatar
You sure its okay to stay with the LS rods? everyone is telling me to go with eagle or somethin? what you think i wanna rev to 9k
Old Jun 8, 2005 | 11:16 AM
ernald711's Avatar
Default Re: (miller.91.HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller.91.HB &raquo;</TD></TR><TR><TD CLASS="quote">
that's a nice build... here's another quality build. https://honda-tech.com/zerothread?id=1161134 check the two other pages for updates and my dyno. itr pistons on ls rods.
DarKStaR5
Jun 12, 2006 11:19 PM
h22a193
Oct 3, 2003 01:24 PM
fastbrakes
Apr 3, 2002 01:47 PM
