EG H22 - would i need injector resistor box?
Re: EG H22 - would i need injector resistor box? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">Which ECU and injectors are you using?</TD></TR></TABLE>
im using a P13 and h22 injectors.
Re: EG H22 - would i need injector resistor box? (SoOHiGH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH »</TD></TR><TR><TD CLASS="quote">im using a P13 and h22 injectors.</TD></TR></TABLE>
then yes, you will need one.
Re: EG H22 - would i need injector resistor box? (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">
then yes, you will need one.</TD></TR></TABLE>
thnx for the quick response guys. time to go to the junk yard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH »</TD></TR><TR><TD CLASS="quote">thnx for the quick response guys. time to go to the junk yard.</TD></TR></TABLE>
np, have fun.
np, have fun.
how can you tell just by p13 and h22 injectors? i thought only obd1 injectors needed the box, and the obd2's did not.
Re: EG H22 - would i need injector resistor box? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">how can you tell just by p13 and h22 injectors? i thought only obd1 injectors needed the box, and the obd2's did not.</TD></TR></TABLE>
This man is correct. 92-96, you need a resister box. 97+, you do not need one. Thats if the injectors are stock.
