Cams for LSVTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeEmDC4 »</TD></TR><TR><TD CLASS="quote">well they didnt do what they say they were gonna do and they sure as hell didnt help</TD></TR></TABLE>
bad tuning... that's all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic »</TD></TR><TR><TD CLASS="quote">Run Hondata with those B's, tune it and I bet he'll pull real power.
Toda's are the ****.</TD></TR></TABLE>
too true... i'm running 180whp with stock b16 cams (stock head) with an s200.
i'd get skunk2 stage2's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">
whats your setup?
whats your setup?
http://cgi.ebay.com/ebaymotors...S%3A1
Up for sale: A Pair of used Crower Stage 2 cams. Part # 63402, fits ALL Vtec B series motor. Cams are used for about 2000 miles in fully built crv-vtec motor. These cams helped me produce 243whp. Awesome cams pulls hard from 4000-9000rpm. Now my car is turbo'd, so these cams won't work for me. Upgraded valvetrain rec: from crower. Cam card included with cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">
whats your setup?</TD></TR></TABLE>
1998 B18B Block (honed, hot tanked, and thoroughly inspected)
LS Crank (balanced and micropolished)
Modified ITR Main, Rod, and Thrust Bearings
LS Rods (ARP lock bolts)
B18C5 P73 Pistons
P73 Piston Rings
B16 Head reconditioned w/new valve job,etc... stock internals
ITR Oil and Water pumps
ITR Crank pulley
LS Oil pan, windage tray, and pickup
Hondata Intake Manifold gasket
All brand new OEM gaskets and seals for top to bottom end
The block cleaned with a fresh hone, decked, and bored out .25 for oversized pistons.
As for the ECU, i went p28 Hondata s200.
B18C5 P73 Pistons
P73 Piston Rings
ITR Crank pulley
Rocket M22's we've got a stock bore, LS/Vtec with Ctr Pistons, and rocket M22 cams/springs and/ret.
207whp
firat 11 sec ALL MOTOR Honda in oklahoma
since then we ran 11.82 @ 112.86
this is on a pretty much stock motor... just Rocket Valvetrain and ctr pistons...
$950 shipped for M22's, Springs, Ret., Spark plugs, and ECU chip BRAND NEW!!!
207whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch »</TD></TR><TR><TD CLASS="quote">Rocket M22's we've got a stock bore, LS/Vtec with Ctr Pistons, and rocket M22 cams/springs and/ret.
207whp
$950 shipped for M22's, Springs, Ret., Spark plugs, and ECU chip BRAND NEW!!!</TD></TR></TABLE>
Nice time!!!!! is your hatch gutted?
207whp
not sure about the comp. but it was runnign on 105 so maybe liek 12.5:1 not sure though so dont quote me...
but we did have CTR cams before and ran a 12.6 on the first pass in the EF hatch w/ the rollcage
