((( Swaping Blocks from OBD1 to 2)))
Hey guys i searhed but could not answer my question still, here is the deal:
I want to put my build bottom end from a 94 gsr into a 97 gsr with a blown motor.
Can i just put the 94 block onto the 97 head and be good? Will that change anything for the 97 teg since it will have to pass emission.
I can just put an LS block onto the 94 head and make it an LV/VTEC.
Any comments suggestion?? Thnaks in advance.
Re: ((( Swaping Blocks from OBD1 to 2))) (GS-Rcivic)
Make sure that you use an oil pump off of an OBDII Bseries as well as the timing belt drive off of the OBDII crank. These pieces are needed for the CKF sensor.
