HELP! WAS I SCAMMED BY A SHOP??
Hey guys,
I have reason to believe that the shop that did my b18c-R swap into my 96 ek swindled me out of some parts. Is there a way to tell the b16, b18c1 and b18c5 cams apart from each other once i take off the valve cover?
Also, is there a way i can tell a type-R clutch cylinder from a 96 dx clutch cylinder? and if they're not exactly the same, are they still interchangable? i had a feeling my clutch would feel a lot stiffer once i put the integra motor in my car, but it feels just as soft.
am i being paranoid?
Re: HELP! WAS I SCAMMED BY A SHOP?? (llxzxll)
you can tell the markings on the cams, which they are. Are you talking about a salve cylinder or master cylinder?
The type r master would not work with out modification and the civic/integra slaves are both the same
Re: HELP! WAS I SCAMMED BY A SHOP?? (jdmcivicferio)
Hopfully this will help you out.. Good Luck
https://honda-tech.com/zerothread?id=1220642
craigttnelson
09-18-2009 03:44 AM
