Crx Dx to d15b vtec help
Hey hows it going having a problem with my motor swap . Just finished the swap and there is nothing wrong with the wiring or anything the problem is when I accelerate at half or even 75 percent throttle it does fine but when I floor it it just bogs down Its getting 40 psi worth of fuel pressure even when you floor it and its not throwing a single code im think maybe a bad tps sensor or something is wrong with the injectors if you can give any advice please do. thanks
RotiEatter
06-22-2003 08:35 PM
