Question for Hybrids w/H22A
New User
Hi all. I was wondering if anyone with an H22A swap has had problems with oil consumption. It seems like a fairly common problem with the prelude (which I have) but no one knows what's going on. I tohught I'd ask you guys to see if it's an engine problem. What ECUs do you use? Thanks for the info
New User
Re: Question for Hybrids w/H22A (Steppin Razor)
It all depends. Sometimes I will go through approx 1/2 qt between oil changes. Sometimes i will not go through any.
As for the ECU, mine is from a GSR.
