My B18C1 hybrid doesn't want to start after sitting for a few days...
It will turn over, but doesn't want to fire up. Is this a fuel issue?!
I know that ignitors have a tendency to go bad. I had to change one before I went hybrid with my stock 1.5 non-VTEC before.
Any help or suggestions would be appreciated.
-Todd
-Todd
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: My B18C1 hybrid doesn't want to start after sitting for a few days... (Yellow Dragon)
do you know how to check for spark? use a spark tester (maybe $5) and you'll know if it's your distributor. for fuel...turn the ign to on and listen for the fuel pump. if you hear it, then that's good. install a fuel pressure gauge to check that there is pressure in the rail. if you can hear the fuel pump "whirring" and it pressurizes, then i bet that it's something with your spark. try that.
1 Post
Check the Ignitor...
Also, the Sump fell off of my Fuel Pump and everything was working god, but it wasnt sucking up any Fuel...Also check if your throwing any Codes
Dave
Dave
zoopreme
02-23-2010 11:15 AM
