D16Z6 TO d16Y8 HEAD SWAP HELP!
New User
Does anyone have any info on a d16z6 (92-95 sohc vtec) to d16y8 (96+ sohc vtec) head swap. I have a single came turbo, greddy kit, and I did the head swap but I'm getting a check engine light code 1 & 4 (O2 sensor & crank angle sensor). Problems seems to be comming from the distributor. The z6 is obdI and the y8 is obdII I had to rewire the distributor because the harnesses were different, but all the internals are the same even the wire colors and everything (I dont think I screwed it up). If anyone has done this before or can point me in the right direction let me know, later.
-Derek-
-Derek-
shawnperolis
17
08-30-2013 11:19 AM
