will a turbo fit in a b16a crx hybrid?
What kind of problems should I expect to run into? Just in terms of getting it to fit . . .
[Modified by Reverend, 11:40 PM 8/28/2001]
Re: will a turbo fit in a b16a crx hybrid? (Reverend)
you should have no problem fitting a turbo in a b16a crx. hasports told a friend of mine that there is no problem with there mount kit...
New User
Re: will a turbo fit in a b16a crx hybrid? (rainforest)
I am currently using a HAsport kit in my EF9 and I don't see how you could fit a turbo in. The mount kit places the motor more forward which limits you to room for a turbo kit. The best thing I would do would be cutting and rewelding the mounts, I have seen this done on all the turbo ef's at the track.
Re: will a turbo fit in a b16a crx hybrid? (EVOCELICA)
I've done two, my own and another, in both I rewelded mounts, and still did not have room for a turbo. We had to use half size radiators in order to clear the turbo. One setup used a custom manifold, the other used one from a Drag kit.
RevHard claims to make a kit to fit in a CRX with Bseries motor.... check them out thats prob the best thing.....
