99si b16a2 ?/ p28 chipped or p73 97/98 ecu?
Im doing a swap in 96 cx and need info on using a p73 or p28 w/adapter harness wich way would be better for future upgrades cams,v/springs,retainers,and arias pistons?
Re: 99si b16a2 ?/ p28 chipped or p73 97/98 ecu? (Kermit)
if you wanna make your ECU life easier...stick with an OBD1 ECU....
they're more reprogrammble friendly than OBD2 ECU's.
some other tasty knowledge:
whether you get a P28, P30 (JDM or US), P72, or P61 and decide to go with a mugen program on it, it does NOT MATTER which of those ECU's you get...the program will run same on any of these ECU's. So..I suggest you get a P28, since they're cheaper than a real DOHC Vtec ECU. You can get the P28 converted to DOHC VTEC mugen spec....if you didn't know already.
Also..I provide that service
New User
Re: 99si b16a2 ?/ p28 chipped or p73 97/98 ecu? (Katman)
How much do you advance the timing on the mugen program. I am getting one from a freind that you did and he does not know.
