OBD II motor into OBD I car...what to modify??
1 Post
I'm just asking this question so that I know in the future. What do you have to do to motor in order for it to work? You have to re-wire the distributor, correct? Anything else?
Thanks
Craig.
Thanks
Craig.
Re: OBD II motor into OBD I car...what to modify?? (fowler)
No need to modify the Engine nor the Chassis of your car.
It is all Plug N' Play, as long as you use a ODB-1 ECU and assuming it is an EG body you'll be OK !!! TRUST ME !!!
[Modified by Honda4CX-R, 7:48 PM 8/7/2001]
1 Post
Re: OBD II motor into OBD I car...what to modify?? (Honda4CX-R)
Yeah, I know about the chasis...that's no problem.
But you don't have to do anything to the distributor in order for it to work with the OBD I wiring harness? Like, rewiring so that the plugs match up?
Craig
Craig
New User
Nope. Totally PNP
The only "tricky" part is reversing the ploarity of the IAB signal. The OBD1 ECU uses a positive trigger and the OBD2 engine uses a negative trigger. Its pretty easy to modify though. It took me about 10 minutes with a Helms manual to figure it out.
Mike
Mike
crxhybrid1320
06-09-2004 07:42 PM
275Performance
01-01-2003 12:37 AM
