91 Si rear disc swap question????
New User
I have a junk crx and it was a 90 Si, I have a 91 Civic Si and want to take the rear disc brake and put it on my civic, drums suck. Now what I needed to know is what all do I need to take of the crx to get the swap done right. thanks for the input...
Re: 91 Si rear disc swap question???? (91sifreak)
Just take off the discs, calipers and the hubs. Or to make it even easier, just swapt the rear trailing arms, brake lines and e brake cables.
Moderator
i believe everything will work cept for the ebrakes...but not sure on the ebrakes...jsut didn't put them on my 91 si....but take trailing arm and everything will bolt right p to the ef
late
chad
14
late
chad
14
for rear discs swap the whole thing, including the brake lines, and LCAs which have a sway bar hole
as far as m/c sure you can swap, it should be slightly bigger also swapping a prop. valve might help the balance off dc/dc setup
New User
Re: 91 Si rear disc swap question???? (eg6ajk)
Will the master cylinder I have right now work if I hook up all the brake lines or should I do the whole thing, can I just use the prop valve off the crx and use it on mine? thanx
GeoMetry
11-11-2015 09:20 AM
bprsk8r4272
Suspension & Brakes
15
10-22-2007 12:29 PM
crxmadness
Suspension & Brakes
02-20-2006 04:25 PM
