h23 swap
Old Jan 26, 2003 | 10:53 PM
boostedblack99's Avatar
Default h23 swap
hey i had a few questions my buddy just did a h22 in his 92 lude and gave me his h23 for $200 with everything ecu, axles, wireharness and everything else i will need. can i just remove my wiring harness and use that complete harness or no. they are both odb1 and i dont need to wire a vtec...by the way this is going in a 1993 del sol. if anyone has pics on installing the shift linkage that would be cool to
thanks
Old Jan 27, 2003 | 11:01 AM
Slopoke's Avatar
Default Re: h23 swap (boostedblack99)
You will need to modify your stock delsol harness.
Also, you cant use the h23 axles and I dont believe you can use the h23 ecu either.
Do a search for what you will need for an H22 swap. Most of it will be the same as far as mount kit, axles, cable shift assembly, etc.
I honestly dont know what you would do about the ecu.
You may beable to have your stock ecu rechipped.
Old Jan 27, 2003 | 07:58 PM
Default Re: h23 swap (Slopoke)
hmmm well what if i use the h23 ecu and harness??? that would work...right???
Old Jan 27, 2003 | 08:13 PM
Slopoke's Avatar
No, the prelude harness and ecu will not plug into your delsol.
Coldth1
Apr 6, 2005 04:34 AM
spnbb2
Aug 5, 2004 09:35 PM
humtake
May 20, 2003 04:46 AM
brawl
Apr 3, 2002 12:37 PM
