jdm b18c in 96 coupe - some questions *used search*
maybe my search skills suck; but i dont wanna get flamed and such.
i got a b18c out of a jdm gsr (sirgII i think)
anyhow, ive replaced teh plugs & wires and new distributor and all taht jam.. oil seals valve cover gasket, and its all prepped and prepared to be put in.
now since the motor is OBDI - and my car is OBDII i got that skunk2 converter thing to make things easy.
but i heard there are some plugs on the motor you have to re-pin. which ones are these? and in what way to re-pin, does anyone happen to have a diagram?
should i just get all the 99-00 SI motor mounts? or do i only need the rear one, and will the drivers side one work?
also any heads up in problems that may occur would be great.
thanks in advance.
-Paul
thanks in advance.
-Paul
Re: jdm b18c in 96 coupe - some questions *used search* (Palm Beach h00kup)
The repinning they are probably referring to is at the distributor. Your 96 engine harness at the dist is obd2 and that gsr dist is obd1 and I dont think that they will plug directly into one another.
Re: jdm b18c in 96 coupe - some questions *used search* (Halo)
just get a 96-98 Civic ex harness
