02 sensor problem on B16a
Old Jan 27, 2003 | 05:03 AM
simonc's Avatar
Default 02 sensor problem on B16a
Does anyone know how many wires(4 or 2) the o2 sensor is meant to have on a B16a? Just swapped a B16 into my civic which used to have a ZC engine. the check light is on and the problem is the o2 sensor.
Old Jan 27, 2003 | 06:02 AM
CHEETAH's Avatar
Default Re: 02 sensor problem on B16a (simonc)
it doesnt depend on the motor, it depends on the chassis being used ... which you didnt mention
greg
Old Jan 27, 2003 | 07:03 AM
simonc's Avatar
Default Re: 02 sensor problem on B16a (CHEETAH)
The motor is a 1997 B16a. The chasis is an EG hatchback
Old Jan 27, 2003 | 07:07 AM
CHEETAH's Avatar
use the 4 wire sensor which mounts on the collector. Since you have an EG then you dont need the rear o2 that mounts after the cat.
greg
Old Jan 28, 2003 | 01:37 AM
simonc's Avatar
The car as standard has a one wire sensor, will a four wire fit into the wiring plug?
Old Jan 28, 2003 | 06:22 AM
CHEETAH's Avatar
yes, when using the 92+ dohc engine harness it will have a 4 wire o2 plug for the o2
Old Jan 29, 2003 | 01:05 AM
simonc's Avatar
We're used the car's original ZC harness as it was obd1. Will this work as the original o2 sensor is just a one wire??
Old Jan 29, 2003 | 07:50 AM
simonc's Avatar
Of the four wires, how many go to the ecu, and to which pins??
justin1785
Mar 14, 2011 09:03 AM
robbys89
Apr 24, 2009 08:10 AM
B16acivicsedan91
Feb 23, 2007 03:46 AM
SkoundrelUSA
Dec 23, 2004 07:33 PM
DreamSpeed
Jan 11, 2002 02:28 PM
