where's evap purge on 2nd gen JDM B16A...
Re: where's evap purge on 2nd gen JDM B16A... (HondaCutter)
bump...i did a search and couldn't find anything...and on hyrid.honda-perf.org they only speak of the b16a2 swap, not the JDM b16a. so my question is...Is there an EVAP purge solenoid on the 2nd gen b16a?
its a little canister on the intake manifold. There is one vaccum line going into it, and then one comming out on a 90 degree angle, and there is one plug with three wires going to it. If your new b16 does not have one, you can use the ond off the old d-series motor, it is held on with one 10mm bolt to the back of the intake manifold. HTH trey
Reelizmpro
09-24-2004 12:22 PM
