Fuel pump will not prime!
Old Jan 28, 2003 | 03:17 PM
chad174's Avatar
Default Fuel pump will not prime!
Hi, i did a 92 b18a swap in my 89 dx auto. I coverted from auto to stick, and i can crank the car freely. the main relay is fine, i have tested it with another relay and it did the same thing. I ran wires directly from the ECU to the injectors, and i havent done anything with the 2 injector plugs from the dx harness, they are just sitting there. I'm wondering if this has anything to do with it. someone please help.
Old Jan 28, 2003 | 08:01 PM
chad174's Avatar
Default Re: Fuel pump will not prime! (chad174)
bump!
Old Jan 29, 2003 | 07:35 AM
Jason kiDD's Avatar
If you main relay is working then check to see if you are getting the 12v initially when you put the car in the ON position at the pump wires. Also check the pump itself for continuity to see if its good or not..
I had similar issues and I just crimped down the connectors on the pump tighter and I was good to go..
chad174
12
Sep 1, 2017 08:00 PM
SoFresh1189
17
Jul 9, 2010 07:03 AM
BBY98EX
Jul 20, 2008 12:06 PM
mr_hahn73
15
Oct 21, 2007 10:17 PM
bc matt
Mar 27, 2005 09:18 PM
