obd1 GSR wiring harness on lsvtec...
well ive hooked all the plugs up that i could find a match for them. i have these 3 left over.. can someone tell me where they go.
thanx.
the green plug is not connected.. it just happened to be touching the wall when i snapped the pic.
BTW.. its a ITR head.
[Modified by baonest, 6:47 PM 2/2/2003]
thanx.
Re: obd1 GSR wiring harness on lsvtec... (baonest)
Some guesses:
crank fluctuation sensor
knock sensor
o2 sensor
alternator
Which ones on that list you have plugged in already? The alternator has a plug in addition to the large line...
knock sensor
o2 sensor
alternator
Re: obd1 GSR wiring harness on lsvtec... (trbob16a)
i found out that the obd1 engines dont have crank sensor.. so thats out.. and i beleive obd1 also have no knock sensor. so thats out. and i have the alt. hooked up and the pluf for the o2 is also hooked up.
The Crank fluctuation sensor has 3 wires for it... both of those has 2 wires running to them. The knock sensor only has one wire running to it, so it cant be that, either. O2 sensor has 4 wires running to it.
Im just thinking IAB's (Does it have a plug?), Power steering (but it looks like that is hooked up in the pic). Also, IACV valve.
Post up what color wires those are & I look them up in my Helms, Karoush. PM me if you aint heard from me & ask me again if I dont respond.
Pete
Pete
Re: obd1 GSR wiring harness on lsvtec... (pest)
the green cap is a single wire.. its red w/blue stripe
another plug is 2 wires, pink with blue stripe and yellow with black stripe
another plug is 2 wires, yellow with black and blue with black stripe
thanx pete
thanx pete
There you go... have fun.
Pete
I have the 95 Teg manual... Fuel & Emissions is most of the engine harness schtuff.
That section is all tore up in mine... but it doesnt compare to my 6th gen civic Helms... the binds are gone & Im afraid Im gonna lose lots of pages.
Hope your **** runs... you taking it to Alex's place to dyno when you get it done??
Pete
Pete
Which Alex? Jeanna's Alex is living w/ the guy who's trying to get that sr20det in that s10 running.
The Alex @ Eurospeed has the dynopack we frequent<<< the one I was talking about.
Hell... come over to the board & bs... keep it off here.
Pete
Pete
maybe u guys can help me
i got a b16a2 and got a 2000 gsr harness
Ok i got this ....
1 Gray round plugs ... yellow with black / blackwith blue 2 wires (IAVC valve i think )
2 Gray round plugs ... red with yellow / Green with black 2 wires
3 Gray round plugs ... red with blue / black 2 wires
4 green round plug ... red with blue 1 wire (knock sensor i think)
where do those other plugs connect to ?
Ok i got this ....
sive
13
06-11-2013 05:23 PM
