b16 into EK hatch specific questions
planning on getting a b16 swap in my ek hatch, here are a few questions i am hoping you guys could answer:
*header- what type of header should i use, not brand, but car, im worried about fitment issues.
*CAI- same thing(fitment issues), for which model should i buy it for?
*clutch and flywheel - same as above
--thanks for any help
Re: b16 into EK hatch specific questions (motohatch557)
dunno the first two questions but the flywheel/clutch should be for the B16 or watever tranny you're gonna use.
Any B series header will fit your motor.
No matter what header you use, you will probably need to have your exhaust modified a bit.
This is very cheap to do. Just take it down to midas. It will probably cost you $15-$20.
You can use the cai for a '99 si if you want it to go through the factory hole.
Re: b16 into EK hatch specific questions (Slopoke)
from what I've read, jdm itr 4-1 header bolts directly to EK hatch cat-back without the cat. Later on if you get a cat, you can have a muffler shop cut a section of the catback to fit a cat.
aamadeus
17
02-26-2005 07:31 PM
