LSD Transmission identification.
Old Feb 1, 2003 | 02:11 PM
KOALA YUMMIES's Avatar
Default ..
Old Feb 1, 2003 | 02:40 PM
joe_bocc's Avatar
Default Re: LSD Transmission identification. (KOALA YUMMIES)
There should be a stamp on the Transmission casing saying "LSD".
Old Feb 1, 2003 | 02:52 PM
Kamin's Avatar
Default Re: LSD Transmission identification. (joe_bocc)
if theres no stamp you have 2 options
1) put car in gear, jack car up. turn one wheel clockwise, the other should turn counterclockwise. (im not 100% sure that is the correct way to do it.)
2) pull an axle, if you see a big *** metal bar, its NOT an lsd transmision.
Old Feb 1, 2003 | 03:22 PM
96-EJ6 B18C's Avatar
With both front wheels in the air they should both spin the same direction if one is turned if the tranny is LSD...if its not then one will spin onw way and the other will spin the other.
Old Feb 1, 2003 | 04:15 PM
Hondaaccordvtec's Avatar
Default Re: LSD Transmission identification. (96-EJ6 B18C)
Not necessarily on both wheels spinning the same direction while the car is on jackstands. I have a JDM H22a w/ LSD tranny. I have had the car up on jacks many times. Turned one wheel forward and the other rotates in the opposite direction. But if I do a burnout, I leave plenty of rubber from both wheels with witnesses on both sides of the car watching the front tires. I believe the type of LSD I have is called "Torsen" which acts like an open dif. in normal circumstances but get on it and it will detect slip and drive both wheels at the same time.
Old Feb 1, 2003 | 04:33 PM
Kamin's Avatar
Default Re: LSD Transmission identification. (Hondaaccordvtec)
see now you know why im not 100% sure.
the 100% test is pulling an axle and looking at the differental.
Old Feb 1, 2003 | 05:42 PM
Nameless RB26's Avatar
Default Re: LSD Transmission identification. (Kamin)
That's the service manual way of checking for a properly operating LSD. It doesn't tell you whether you have one, because an open differential acts the same way.
To find out if you actually have one, you need to look at it, like you said...
Old Feb 1, 2003 | 05:45 PM
Your LSD moves both wheels when burning out? From all of the burnouts I've done with my LSD ITR tranny, I've yet to see one leave both marks on a small burnout. When my tires heat up more, then both of the wheels move... but when I just burnout for a couple seconds, one tire moves more than the other..
Old Feb 1, 2003 | 06:13 PM
owen_the_soyboy's Avatar
the tranny has to be IN GEAR for this check to work... But anyhoiw, you cant miss it with the axles out. Look inside the hole that the axles go, if you do have a LSD in there, you will see teeth around the hole, most of the way thru, and you could stick a pipe right thru the hole from one side of the trany to the other. If you doo NOT have LSD, you cannot see right thru this hole, there will be a metal rod running across it, this rod is half the size of the hole, you will be seeing the side of the rod.
LSD fawkin rules
[Modified by owen_the_soyboy, 10:16 PM 2/1/2003]
Old Feb 3, 2003 | 10:49 AM
johnsaccord's Avatar
If you got a jdm h22 lsd, the tranny code is: m2b4, whereas the non-lsd is m2a4.
Other tranny codes...usdm h23a1 tranny: m2s4, usdm h22a1 tranny: m2f4, usdm h22a4 tranny: m2ya,
usdm type sh tranny: m2u4. Those are all the one's I can remember.
[Modified by johnsaccord, 2:50 PM 2/3/2003]
Old Feb 5, 2003 | 04:51 PM
paybac4223's Avatar
mine didnt have the stamp on it...but if you can see all the way through the tranny when the shaft isnt in then its lsd...if it has a bar in the way then its regular...
Old Mar 21, 2003 | 07:31 PM
AMG's Avatar
AMG
Default Re: LSD Transmission identification. (paybac4223)
Sorry for a late post, but just trying to find a pic of this on a B18C.
-Thanks
Old Mar 22, 2003 | 07:52 PM
liquid51's Avatar
Default Re: LSD Transmission identification. (Si-G93)
this is pretty much what it's gonna look like:
(you can see the end of the half shaft through the diff.)
This is the Euro R Accord h22, but I'm pretty sure they all look the same.
Old Mar 23, 2003 | 07:40 AM
JV's Avatar
JV
Who?
shocker911
Transmission & Drivetrain
Feb 10, 2011 08:22 PM
gunnis
Sep 8, 2005 07:53 PM
LSegHatchy
Oct 28, 2004 12:20 PM
tencan
Oct 9, 2004 04:45 PM
93b18civic
May 5, 2002 03:19 PM
