Which Mounts for EK type r Swap????
i know im gonna need the L-bracket (#7 in the picture) and the driver side top mount thats near the timing belt but that mount has no number for it??? Any clue what number it is by looking at this pic. thanks
and the page link is http://www.hondaautomotiveparts.com/...+MOUNT+%284%29
thanks
thanks
Re: Which Mounts for EK type r Swap???? (ef ect)
you should be able to find that at a local junkyard pretty easily. any oil filled(top driver side)mount from an ek will work
1 Post
Re: Which Mounts for EK type r Swap???? (DevinW)
Do these apply to B20 swaps into an EK as well?
If you have any motor besides the b16a2 (from an SI), you need to get the timing side mount that is attatched to the block.
Re: Which Mounts for EK type r Swap???? (fowler)
You will want the #1 mount too. The timing belt mount looks like it says 14-1 with an arrow pointing to the numbers. This is from actual experience.
Re: Which Mounts for EK type r Swap???? (ZigenGSR)
BE advised, the driver mount that bolts to the head....99-00 Si isnt the same as the Gsr mount. The SI mount is different. I found this out the hard way.
Re: Which Mounts for EK type r Swap???? (Blown90hatcH)
all the info you need is at http://www.jspectuning.com/6gen
and here is the mount the dood above me is referring to:
[Modified by Trey, 3:20 PM 1/30/2003]
kush_ek
13
06-03-2010 12:24 AM
Del Sol on Steroids
06-04-2007 09:15 PM
