Ls/Vtec question??!!
Old Jan 30, 2003 | 10:12 PM
its WANG yoO's Avatar
Default Ls/Vtec question??!!
i just bought a 92 Ls bottom with Gsr crank and rods and CTR pistons all new bearings and tapped for Vtec oil line already...i bought it from QuickCrx38...the thing is...
i was told that since it has Gsr crank and rods its not Ls/Vtec anymore and its just a Gsr bottom with CTR pistons...is this true?
also...am i gonna make more power with the Gsr crank or an Ls crank with matching rods for both?? i have access to an Ls crank if i need it(buddy is selling one)...i was also told that Ls rods will not fit CTR pistons...
someone help me...whats the best way to go....thanks alot!!!
remember i'll be running a 50shot to this motor also with ITR head and manifold and CTR cams....thanks alot guys!!!
Old Jan 30, 2003 | 11:03 PM
EVOLMTR's Avatar
Default Re: Ls/Vtec question??!! (VTEC93hatch)
LS rods will fit CTR pistons. They just need to be machined.
Old Jan 30, 2003 | 11:14 PM
b18b-HB's Avatar
Yes it is just a gsr bottom end, the thing is you might have to high or to low of compression ( i am not sure) . You will make more power with with a ls crank and rods. Sorry I can not help more
Old Jan 31, 2003 | 08:22 AM
CRX_VTEC's Avatar
if you use a gsr crank then it wouldnt be a ls/vtec anymore. You have to use ls crank and rods mang.. ARP bolts and bore the rods 1mm to fit the wrist pins of PCT's.
BTW. I wouldnt use ANY shot on this motor! The compression should be 12:3-12:5
and unless you tune out the fuel curve.. its going to go BOOM!!!!!
[Modified by CRX_VTEC, 9:29 AM 1/31/2003]
Old Jan 31, 2003 | 08:28 AM
Default Re: Ls/Vtec question??!! (CRX_VTEC)
so what do i gotta do to make the CTR's fit Ls rods???
do i have to machine the head for a smaller comb. chamber?? i was told something like that
i'm running ITR head...someone help me with Numbers....thanks alot! i'm also running juice..is that gonna affect anything..thanks alot!
Old Jan 31, 2003 | 09:01 AM
Jeff C's Avatar
This might answer your milling q's.
As far as helping you with the numbers...do you mean compression ratio? If so, then try here.
GSR_hatch936
Apr 30, 2008 06:48 PM
Coolest Dude Ever
Jun 8, 2007 02:39 PM
EGcivicvtec
Feb 13, 2006 09:54 AM
bigmikerich20
Sep 20, 2005 07:01 AM
