Where do i buy this bracket for my hybrid!
im just going on what hasports instructions said
If the B-series you are installing is not either a 89-91 Sir or 90-93 Integra then you will need a different engine bracket to fit the Hasport mount kit. The part number for the first generation B16A bracket is 11910-PR3-010. With this bracket you can use our mount kit to install the B16B, B18B, B18C, B20B and B20Z.
I am putting a JDM B20B in... So it says to use that instead......
where do i buy this 11910-PR3-010?????
it says
The correct rear bracket is from an 89-91 SiR or 90-93 Integra, part number 50827-SK7-020. Thats if im putting a B16 or B18A only, not a B16B, B18B, B18C, B20B and B20Z.
It has nothing to do with hydro tranny, it has to do with motor position.
it says
Re: Where do i buy this bracket for my hybrid! (irev210)
i think you buy it at acura. the part they're refering to is the timing belt mount bracket. That bracket is different compared to any B series other than the B16a and 90-93 teg.
http://www.acuraautomotiveparts.org/...5=ENGINE+MOUNT
I think iten 11 is what you want
HTH
chris
[Modified by NCchris, 8:28 PM 2/2/2003]
HTH
chris
irev210
02-03-2003 11:44 AM
