Radiator Ideas (H22--> Eg)
Will the stock EG civic radiator work when I do the h22a swap or will I need a new fan? Would a 300 dollar investment into a del sol vtec radiator be worth it, I only plan to use it as a street car but also let it loose a little bit. just trying to save some bucks.
Re: Radiator Ideas (redlineh22a)
A Del Sol VTEC is only $115 from http://www.radiators.com
You *can* use the stock one..but it will constantly run [i]slightly[/b] hot, which in the long run isn't good for the engine. The fan will also come on a lot..especially in traffic.
Save the headaches and get a Del Sol VTEC radiator (like i said...$115), and a slim line Hayden fan from pepboys...$70. Works great together.
Re: Radiator Ideas (hot_EG)
One thing is that the fan is slighly touching the bleeder valve on the clutch slave cylinder now with the dual core radiator in. It is a very tight fit.
Re: Radiator Ideas (laugHin22CX)
as stated above use the del sol radiator , and you can trim awy some of the shroud on the stock one, but go to any auto parts store and pick up a slim fan for like 80 bux, looks much more clean.
Re: Radiator Ideas (H22EK)
not trying to steal ur post but anyone have a gsr radiator in with there h22? how tight a fit is it with a gsr radiator? i also have the hayden pep boys fan.
Re: Radiator Ideas (p10hlm)
GSR radiator will fit, you just need very slim fans. On an EG, you cannot just go an get any slim fan on a dual core radiator from the parts store because on the EG, the H22 slave cylinder is closer to the radiator fan than on an EK H22 setup. If you plan to run just "any" slim fan, then you need to change out your slave cylinder to an Civic/Integra slave cylinder....... it doesn't just bolt right in, you need to drill out one of the mounting holes 1/4" to allow it to bolt onto dual core radiator. If you run a single core radiator, then you don't need to do this.
Re: Radiator Ideas (Newman)
You can also position the fan different on the radiator to get more clearance...
At the moment, I'm running the stock radiator.. single core.. and it never heats up above slightly below half. Of course, it's upstate NY, and the average temp has been 1 degree, literally, for the past like 3 weeks. I plan on going GSR radiator in the spring, just to keep my baby cool. I'll haveto fab up some mounts, but hey, I think I can do that, since I just swapped motors.
Re: Radiator Ideas (EK22Tim)
My buddy, (tinker219 some of you may know) can sell me a GSR radiator for 100 bucks should I do that or would the del sol vtec be better deal?
Del sol vtec would be a little lighter and more compact than the gsr. The gsr is kinda overkill. Go ex automatic or del sol vtec..Both dual core.
Re: Radiator Ideas (fastwanabe)
im a little worried about my radiator setup. i use del sol vtec w/ FAL fan and i actually had to file down the bleeder valve on the clutch slave cylinder to avoid interference with the fan blades. hope i can still bleed my clutch...btwi use hasport mounts...maybe my frame is slightly bent? i dont know
speedraycer25
07-14-2006 03:16 AM
explosive
11-01-2003 07:58 PM
