AC Autotechnic Al. Oil Filter Block?
AC Oil Filter Block Aapter provide an easy way to install oil pressure and Oil Temperature gauge sensor, made from billet aluminum and simple to install this adapter goes between the oil filter and engine block
What are your thoughts on this?do you think it would work for LS/Vtec Oil feed line?
[Modified by tnbigdawg, 6:17 PM 1/31/2003]
Re: AC Autotechnic Al. Oil Filter Block? (tnbigdawg)
what about for an h22 or an engine that has a stock oil cooler, does this sandwich between the stock oil cooler and the oil filter or does this replace the stock engine oil cooler and sandwich directly between the block and the oil filter? I need one so I need to know!
Re: AC Autotechnic Al. Oil Filter Block? (Hondaddict)
bump?
I just wanted to know if it would work, so I can take off my brass tee(I heard it can do serious damage to the block)
Someone Please Give Your Thoughts on this.
TIA
TIA
HT's Biggest Loser
Re: AC Autotechnic Al. Oil Filter Block? (Hayasa15)
I dont see why it wouldnt work. If you dont care for the AC piece Greddy makes one.
what about the stock oil cooler, does this AC adapter sandwich between that and the oil filter?
PICS PLEASE
PICS PLEASE
I'm wondering if there would be any benefits to this, I've never seen/heard of it before... also, does it allow for oversized filters?
I'd like to hear from anyone that has one, if no one's got one I'll have to run out and buy one myself
How much is it and where can we get?
http://209.87.151.155/search_results...l=1&subcat=ALL
I'm using it for my ls/vtec-t here:
https://honda-tech.com/zerothread?id=389652
creechrr
05-06-2003 06:43 AM
