Engine harness question
Old Jan 27, 2003 | 09:17 AM
SC61HB's Avatar
Default Engine harness question
I'm going to be getting a swap very soon. I am looking at a JDM B16A2 complete swap. I own a '96 civic dx hatch. My question is, can I just use the wiring harness that comes with the engine and put it straight into the engine bay and plug everything in, or do I have to cut plugs off of the B16A2 harness and put them on my DX harness?
I used search first, but couldn't find anything.
Old Jan 27, 2003 | 10:50 AM
Slopoke's Avatar
Default Re: Engine harness question (zgrieger)
Modify your stock DX harness.
Old Jan 27, 2003 | 11:31 AM
Halo's Avatar
or buy a 96-98 Ex harness
Old Jan 27, 2003 | 11:43 AM
VTECVillain's Avatar
Default Re: Engine harness question (Halo)
That would be the easiest thing to do if you don't mind spending the $ on the EX harness. If not, the stock harness will work with the addition of the VTEC wiring and knock sensor. You can't use the harness that comes with the motor other than using it for extra plugs and wire.
Old Jan 27, 2003 | 01:56 PM
SuperMan19's Avatar
New User
there's a JDM b16a2? Or is that the same as a B16 SiR2 motor? Cuz someone told me that I would have to get the obd1 to obd2 harness conversion to do that swap. I have the same car and wanted the b16 SiR2 motor and mentioned nothing about the add wires with stock harness etc stuff. Can anyone clear this up for me?
Timothy Yhtomit
Feb 26, 2019 02:25 PM
shocker911
May 14, 2010 02:29 PM
rustanghunter
Mar 26, 2010 07:58 PM
all4show97
Nov 6, 2005 01:44 PM
